1JZGTE antilag 2 step rush racing
armyastro
full body shave t04 mk3
Sep 16, 2005
222
radcliff ky
I installed the Antilag into my Lexus SC300 with a 1JZGTE. It works great and makes alot more psi than all the other 2 step/antilags i have seen and for a fraction of the price. It is a simple install with 3 wires, 1 red power wire for ign, 1 black wire for the ground and 1 white wire for the crank sensor positive wire labeled NE on the ecu. I talked with Jason and he said to post a few vids of it on here for the 1JZ guys just let me know or go to http://rushracingdev.com
very fast shipping also and the wiring and hookup took about 15 minutes.
http://www.youtube.com/watch?v=lf06BhxAEtU
http://www.youtube.com/watch?v=I8KOhmMau4c
http://www.youtube.com/v/lf06BhxAEtU
http://www.youtube.com/v/I8KOhmMau4c
Spaniard
524
La pearla PR
There goes the turbo in two weeks. Does anyone realize how much stress this puts on the engine? Its a great unit, but for the long run, it's just not going to happen. Anyone please correct me if I'm wrong.
armyastro
Sep 16, 2005
222
radcliff ky
they blow turbos if used ALL the time like the autocross or dirt racing where you use it the whole race. if you use it for launches, that few seconds wont hurt it that much. it isnt a full antilag, it is a 2 step but acts like an antilag with the boost build and popping. if you use it ALL the time it will blow the seals and the exhaust side. but i honestly dont see it happening unless you are stupid with it and use it just for daily driving.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Yeah two step is a type of ignition launch control. Anti-lag is what builds boost. Just looked at the site. That is a great price for the unit it is
armyastro
Sep 16, 2005
222
radcliff ky
very nice price and i have been messing with it for a few days.. not alot or enough to hurt anything but it is a very simple to use antilag.
tissimo
Stock is boring :(
Melbourne, FL
Spaniard;923845 said:
a 2 step is not suppose to build boost, it's anti-lag that does. two very different things.
it does.. 5k w/ my 67 would build ~ 8 psi.. antilag I could get whatever I had the boost set to tohugh
buldozr
362
North Texas
2step drops cylinders at a preset rpm, antilag retards timing(alot) to make the unburnt fuel and air to explode in the exhaust manifold(creating sick boost)... antilag is really hard on turbos due to its violent nature.
armyastro
Sep 16, 2005
222
radcliff ky
lol it is for autocross or for sprints. alot of people use it for drag racing due to it being able to let your car build boost in neutral then letting you launch with boost rather than waiting for the car to hit the right rpm while moving to make boost. it is also used as an antilag for shift changing and holding boost. if you use it for a fast second and launch and not use it all the time it is fine for the turbo. sure it might mess the seals up or bearings but it will be awhile. it is hard on the turbos cause it detinates in the manifold and spins the turbo fast to build the boost.
