1jz xspower t61 dyno
boostindoo
179
raleigh
hi all check out my dyno
been tuning for about 3hrs working out bugs, it was 90+ degrees and probably heat soaked. im wondering if the #'s were low and the tuner said that the engine is running good and he thinks its making good power for the setup. he also told me the dyno reads lower than a dyno jet. feels great on the street though. was hoping to be close to 450hp on this setup. he said if it cooled down, i would probably put down 375 or so.
1jz
xs t61
ebay intercooler
2.5 cool pipes, 3 hot pipes
hks ssqv bov
tial 44mm wg
ebay manny
3in turbo back
walbro 255
mk4 550
aeromotive fpr
innovate wb
aem truboost
stinger ems
osgiken twin disc
stock motor
i think he said he tuned it at 18psi. questions and comments appreciated...
tissimo
Stock is boring :(
Melbourne, FL
Those numbers are very low. The turbo is garbage or you have a bad tuner.
My buddy put down 345whp with only 12 psi on a gt35r.
boostindoo
179
raleigh
I know the turbo is bottom of the line...I'm gonna get a different
real turbo when this one blows...trying to get the af and ignition timing
stuff from him
he knows what he's doing I'm sure, his name is Kevin and he works at
majestic motorsports in Jacksonville nc...they do alot of supras!! The
shop supra makes 1500hp and run mid 8s
so u guys don't think it's just the stock cams besides the turbo..
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
Yeah for sure,
310 WHP the stock twins will do that AND have 2500 RPM more spool! Stunned if that is called an upgrade!!
Feb 1, 2006
154
Columbus, Ohio
You should have made more power than that....
Now, of course, I will have to say your turbo choice probably wasnt the best.. But those turbos have been good up to ~18psi which should have put you in the 400s without too much issue. The Stinger should have definetly helped you get there
boostindoo
179
raleigh
I think I would be around 400 on a dynojet....it certainly feels solid.
Well what turbo then, street turbo? Driftmotions? Master power??
Don't wanna spend too much, want to do 2j block and cams...
Feb 1, 2006
154
Columbus, Ohio
Well Im sure youre aware of the saying: you get what you pay for. Now, thats not always true of course, but when it comes to something that requires a great deal of precision... I would say spend the extra cash, you wont regret it.
I believe Driftmotions turbos are good quality, and there is also SoundPerformance, Garrett, HKS, Turbonetics, etc...
That 2jz block and cams with a good turbo and everything else you have should put you in the upper 400s with out too much problem
boostindoo
179
raleigh
i think im gonna go with a master power turbo, good things about them and within my price range....i was boosting around town and im guessing everything isnt heatsoaked anymore, i was spiking 22.5psi. i think im just gonna run off the wg spring for now which is at 1bar...
if i posted a log could u guys help me out?? i really think im closer to 400hp, gonna take it to a dynojet in about 2 weeks... anybody know much about the superflow dyno?? they said it would read lower than a dyno jet, but how much?? thanks again..
Gritz
155
nc
stuff from him
Yeah that white supra that he has is a beast...I went to that shop before, the whole crew was stoked when they saw my 4g63T turbo mightymax truck...the owner was also stoked when i told him that i was putting a 1jz in a 260z, of course he had the "yeah right" kind of questions he was asking me..lol I should be driving the 260z in a couple months!!
I guess for what you paid 350+whp ain't bad..i say raise the boost to 20-22 psi and see if you can make 400whp..run that turbo... save up and buy the turbo you really want, either way now your feet are wet..:evil2:
boostindoo
179
raleigh
Rakkasan, what turbo?? What psi? Race gas?? Stock cams??
I'm torn between upgrading the cams or a diff turbo, I
know the cams are one of the best mods for our engines,
but if I can make 500 without it, I might just do it a lot later instead..
thesupragod
183
Mount Vernon, Ohio
my vote is for turbo. cams will yield a ton of extra power, but that turbo is going to take a shit, i couldnt tell you when, but it is, and when it does you will have to replace it. That is not anywhere close to where your power should be.
i have a similar setup, 440's, afc neo, and 2jz usdm cams, and at 15 psi i made 450 hp.
I dont think that the cams made more than a 25 hp difference.
boostindoo
179
raleigh
How hard is it to tune if I slap on a turbo, like a master power t70..
I can make adjustments etc but don't know why or how much what to
look for...sigh...would love to learn though
I'll answer for Mark since he isn't here at the moment...........:icon_bigg
He had a www.driftmotion.com 61mm turbo running 23-24psi with racegas. I think he had some 2jz cams installed, but I couldn't swear to it.
On my 1jz I made 543rwhp @ 24psi with crower cams. I daily drove mine @ 17-18 psi and it made 447rwhp. with 12rwtq.................:biglaugh:
rakkasan
Currahee!!
Fort Campbell, KY
IIRC, I was running about 23psi and C16. The turbo was a hybrid 60-1 (61mm turbine). The turbine was a GT wheel and the CHRA was Turbonetics. As for cams, I use modded USDM 2J cams.
I think the secret to my success falls on both the turbo and using Stinger ECU. With this set up, I ran 478whp daily.
