so the topic of this thread is I want to know what I can make hp/tq numbers while having a reliable daily driver.
What I have right now is : a 1989 mk3 swapped with a 1jz. Swap is almost complete. I am running a bone stock 1jz. With a t4 57 trim driftmotion turbo 58 a/r on exaust and 57 on intake side. Full 3inch blitz nurspec exaust, test pipe, 2jzgte harness and ecu, mk4 550 cc injectors w/ resistor. Afc neo if needed. Greddy profec b 2 boost controller and timer. Zeitronics wideband and egt . Upgraded dmotion intercooler, also 2jz map sensor, I haven't decided yet what I want to use. I have a stock jdm aristo ecu, or a jdm mines chipped ecu, which I think is chipped not just for boost cut, speed cut and rev limiter, I think its for bigger than stock fuel, so might be good for the 550s on a 1jz,
So what do you guys think I can make at the crank? And at the wheels? Also I I'm using the 3.91lsd.
