well i just recently finished putting my 1jz in the car and i realized i had a problem in the wiring when i heard a hissing sound coming from my starter, it was a short in the wiring sparking at the starter, the car turns on perfectly fine, so i am kinda wierded out.
ok the weird part is, i took the negative wire off the motor just to see what would happen, and injector #1 start running and the beeping sound from my ignition turns on, as if the ignition were on(AND IT PROBABLY IS) then i touch the negative back onto the motor, a small spark comes up and it turns off, then i realized that the main relay clicked every time that i did that.. i am so confused!!!
could it be that i wired the c1 connector wrong to the fusebox?
i followed the instructions in how to wire a soarer 1jz into an ma70 thread and eveything else pretty much seems to be fine...
someone please share their knowledge im about to start pullinng my hair out!!!!!
