1jz valve stem seals compatibility?
terror
Antibliss
Jun 13, 2008
242
Alaska
couldnt find if 1jz and 2jz share the same valve stem seals or if any other motor shares em with the 1jz, thanks a bunch
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
Intake Side: 90913-02090
(Same as 2JZ)
Exhaust Side: 90913-02089
(Not the same as 2JZ - Same as 91-97 4A-FE/7A-FE Exhaust Seals)
Not sure if 2JZ Exhaust side seals will work, they probably will, but if you want the exact same ones, order intake seals for a 2JZ and exhaust seals for a Corolla.
Jeff
terror
Antibliss
Jun 13, 2008
242
Alaska
(Same as 2JZ)
Jeff
Thank you very much good sir
