1jz Turbo sizing
kikwear002
174
Ft myers florida
Im trying to figure out whats a good turbo everyone is running.
Goals are 500hp
my setup is
1jz stock engine
31x12x4 fmic
50 mm wastegate
50 mm bov
tublar manifold
650 rc injectors
3 inch full exhaust no cats
still trying to determine to go megasquirt or someother managment.
looking for some to spool around 4k
thanks for the help
s14eva1
SFL
go with a t67 .68 or .58 rear
I would recommend a PFC or Aem to get the most out of your setup efficiently....good fuel,ignition,and timming is most important in my book
RacerXJ220
Interdimensional
Abalama
I recommend Megasquirt. It's all you need unless you're going to build a race car, and will definately give you 500RWHP easy depending on turbo selection.
You'll need a LOT more with the AEM to get working, and for the price of a new PFC, you can have a Megasquirt II AND buy a laptop, and not need extra software with the PFC.
Buy a Megasquirt premade, install it and be happy.
GT35R FTW
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i would get a 63 or a 67
gt35r you'd be pushing kinda high to get those numbers atleast i'd think so
HamsMKIII
Yes, it's fast...
Dec 16, 2005
60
Saginaw, Tx
GT35R FTW
Eh.... AEM is great. Easy to hook up and easy to work with. Don't buy the hype, it's not as hard as you think.
Although, having THIS really helps:
Plug N' Play harness into the Supra. You only have to run 6 individual wires for the injectors to convert it to sequential fire. That's a no-brainer.
- Chris
I
itr206
Guest
for 500whp, a 63 or 67 is alot bigger then you need.
Who cares how high you have to push it, if its in its efficiency range.
Chris, Does Richard sell those off the shelf like that now? Last I talked to him, there was more work to be done to convert over to AEM.
AEM IMO is alot harded to tune with then the other systems out there. I played with the interface and its just alot to take in for a newer tuner. There is alot of screens to get lost in and a lengthy config process before you get started.
But it deff has its perks once you get used to it.
HamsMKIII
Yes, it's fast...
Dec 16, 2005
60
Saginaw, Tx
30-1100. Supra Turbo box.
Richard sort of makes the harness, but he isn't advertising it. The harness is plug and play now for the exception of the injectors. You have to wire up a resistor pack like you were doing MKIV injectors, and you have to run the 6 injector wires over to the injectors. This is because the AEM runs sequential fire and our engines are configured for batch fire. Beyond the 6 wires, it's a plug and play deal.
As far as tuning, the AEM looks like it is very complex, but honestly they have improved it greatly over the past 4 years. I would recommend it over any other standalone at this point.
- Chris
kikwear002
174
Ft myers florida
- Chris
Thanks guys, I think im going to go with the Gt35r. Along with megasquirt. I've been reading there is something special you have to do withg the mega squirt to make it fire the coils correctly? anyone know about this?
aphxero
787
Seattle, WA
Yeah it;s kind of difficult. I'm trying to duplicate my setup right now. I'm sure I'll do it soon enough but it's not a priority. As soon as it's done I'll be posting it.
