1jz Turbo Choice
suprastroker88
Supra Tuner
Jul 16, 2008
453
Bay Area, CA
So I'm new to the world of 1jz. I'm in the process of doing the swap right now and I want to go single turbo from the start. I'm looking to make around 450-500hp and I want a setup that will spool pretty quickly since I'm planning on trying time attck next year but I also want to have ok top-end power. Can you guys give me some good options? gt3071? gt35r? gt4088? Also what manifolds flow better? I dont see too many options for the 1jz?
destrux
1,183
10
PA
Driftmotion sells a pre-modded ebay manifold that fits and is durable, and is affordable. It's got a T4 flange.
As for turbo size... check out this calculator.
http://www.squirrelpf.com/turbocalc/
It's the best I've found anywhere so far, it has a ton of compressor maps and is easy to use. It seems to be accurate, it matched up with my own math.
According to that, a GT3076R is perfect for a 500hp 1JZ. If you go too big on the turbo you'll just have more lag (or run into surge problems if you stick a huge compressor on with an undersized turbine to spool it faster). A GT4088 is way too big for a 400-500hp car.
