1jz trouble again!!!!!
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
ok so the 1j was running great i took a female friend on test drive and did a nasty 1st to 2nd burnout then a 2nd to 3rd good hard pull and went to smack it around a turn and the car sounded like it hit fuel cut or something and then i pulled in the driveway and i let her idle and she went into limp mode . so i ler her sit for a couple days and went to start her see what was upl and now its not in limp mode but when u give it gas it idles down but if you slowly rev it goes up just fine .
**sorry for the life story and run on sentence **
Have you checked for any codes?
Check all couplings and vacuum lines.
Don't apologize for run on sentences when it's just as easy to correct them as it is to type in an apology.........;)
5l_eater
Jan 17, 2007
258
Maryland
i checked all the ic piping and couldnt find any boost leaks . i was thinking mayb map or tps
5l_eater
Jan 17, 2007
258
Maryland
ok so i started my car up today it low idles around 600 and idle still drops when i go to rev it but once i slowly rev it i can let all the way off and keep reving it as long as i keep it ...map sensor ? tps ? or ...... low idle ?
