1jz tach
JCP
The Big Unit
Apr 6, 2006
128
Raleigh, NC
1jz fly is what you need for a 1jz.. there are plenty of them out there.. yes you need to swap over the tach on a 1jz swap if you want to do things right.
tissimo
Stock is boring :(
Melbourne, FL
when i had my stock 1j ecu i would hit the revlimiter at like 7k on my tach in 1st and 2nd.. so like 300-500 rpm at higher rpm
JonoTurbo
Going for broke
CT
againstdawall06 said:
also, while im at it. is the 1jz and 2jz fllywheel the same layout and interchangable?
No they aren't, the r154 clutch and pressure plate won't work with the 2jz flywheel.
