whatever you say man im not butchering this guys thread anymore..
my statements still stand
along with the do what the f**k you want statement
Ric said:I dont see a reason to ever go 2jz.
For the cost of a stock 2JZ-GTE swap with JDM crap twins, I was able to build a 1JZ capable of 700whp
I have the supporting mods sans transmissionOneJoeZee said:Capable of 700... But do you have 700 or the supporting mods to make 700 yet?
Let us know when you get your GT4088 on the dyno. I'm interested to see your results. From your posts, it's sounds like a nice setup but the butt dyno is all relative.
crazysupra2JZ said:Engine ( harness+ ECU)...........$2,100.00
Motor Mounts..........................$180.00
Flywheel................................$310.00
Clutch Kit...............................$435.00
1JZ Bellhousing.......................$318.00
2.5" Intercooler Pipes..............$100.00
550cc Inj. and Fuel Rail...........$100.00
Oil Pan and extras..................$550.00
Fuel Pump 255 LPH ................$110.00
T4 Exhaust Manifold...............$160.00
1JZ Flywheel Bolts..................$45.00
Power Steering Hose...............$90.00
AFPR $150.00
this all comes to around $4500 and i'm still not done. i need a bunch of misc items. this is for a 2JZ....lots of money is needed for this swap. i kinda wish i would've done a 1jz or built my 7M...coulda been done by now with my 7M, and making 500 hp
Ric said:Why 2j over 1j? They both make the same power on the dyno, just one revvs higher and has more useable power (1jz)
csnow said:I have only seen one or two 1J dynos that shows the same torque curve as a 2J. The 1J makes hp in the upper rpm range, but the torque starts to fall off fast. That is why I want to see these "so called" 700 and 800 hp dynos from "the boys" in South Florida. I am betting there is a 25% to 30% hp to torque ratio difference. The 2J is much closer to a 1:1 match. Torque wins races, no one can argue that.
csnow said:You are right, as the HP increases on both the 1J and 2J, the torque starts to drop. I was implying that the 2J was closer to a 1:1 than a 1J. I will still argue that torque whens races, not horsepower. A modded Supra lined up next to a properly modded 5.0, Vega, or Grand National will get stomped at the track. The highway....well, thats a different story.
But to each his own....
Now, back to the original poster, a 1J, 2J, or a 1.5J is money well spent on a MKIII. Good luck on your swap.
