Tried to start my jzx90 1JZ swap in my mx83 Cressida today with no luck. I've hard wired everything as it's going to be a track only car with a switch panel. I hooked up 12V to +B, +B1, BATT, and IGSW, and the two large black/yellow and black/red wires and small black/yellow wire on the body harness plug which apparently power the injectors, ignitor, cam and crank sensors. Ran 12V to the fuel pump and connected the starter solenoid wire. The car cranks and I can smell fuel but it won't start. I hooked my multimeter up to the coil harness and got nothing. The plugs are wet with fuel. The ecu and engine are grounded. I'm stumped, any help would be great!
