1jz swap questions
cpederson
117
wi
whats all needed out of the stock engine bay of a 87 7mgte supra for a 1jz swap? like what sensors and stuff will i need to keep? also am i going to need to upgrade the fuel pump from the stock 7m one? the car will be running in stock 1jz form besides exhaust intake and fmic.
thanks corey
cpederson
117
wi
any one? also will an a/t tranny ecu and harness work with an r154 or do i just need a m/t ecu?
thanks corey
Corey, read this and all the other Stickies at the top of this section first and then if you have a good question, make another thread. The answers you're looking for are already here. Good luck.
http://www.supramania.com/forums/showthread.php?t=29117
yes, the auto ecu will work.
cpederson
117
wi
new question! how shoudl i hook up the fuel lines to the stock 1jz fuel rail? sorry for the newb questions im just looking for some help.
