im looking to see wat parts from a 7m are reusable in the 1jz?
mk3<3 New Member Feb 21, 2010 109 0 0 perris Nov 29, 2010 #1 im looking to see wat parts from a 7m are reusable in the 1jz?
IBoughtASupra New Member Mar 10, 2009 4,455 0 0 Queens, NY Nov 30, 2010 #2 You can use anything from the clutch plate back to diff. You will need the 7M harness to have it sent out to have a few plugs wired to 1JZ harness.
mk3<3 New Member Feb 21, 2010 109 0 0 perris Dec 1, 2010 #3 but im talkin about like starters ....water pumps and all that stuff
JonoTurbo Going for broke Mar 30, 2005 670 0 0 40 CT Dec 1, 2010 #4 You can use the starter, it uses the same oil filter, ...and that's it. They are two very different engines.
