1JZ swap: exhaust decision
nctexan
268
Houston
Raptor Racing.
IIRC the HKS and Tanabe both neck down inside the muffler. The last one you linked is for a MKIV not a MKIII Supra.
hvyman;1508870 said:
You can buy the can tho and get custom 3in piping.
Not an "exhaust" then, it's a muffler.
Bigzavs;1509011 said:
i say make your own, ends up alot cheaper
Maybe true, but only if you have the knowledge. If you don't and you have a shop do it for you, you're at the mercy of their skill. You get a consistent quality from a actual company.
nctexan
268
Houston
Maybe true, but only if you have the knowledge. If you don't and you have a shop do it for you, you're at the mercy of their skill. You get a consistent quality from a actual company.[/QUOT
damn texas boys represent. poodles, I dont have the time, so straight up made to order is right up my alley. damn network is squirely, wont go to raptor at the moment, but I will check it out fo sho. thanks to all for input.
Like I said, unless you have the skills to do it yourself, you're at the mercy of a shop to do it.
I've seen some TERRIBLE exhaust jobs...
nctexan
268
Houston
Poodles;1508698 said:
Raptor Racing.
I did a little research on the magnaflow, which is essentially what the raptor racing exhaust is, just modified. The mufflers Raptor is using both have a 2.25" inlet. Even though they chop off the 2.25" inlet and weld on a 3" inlet, the muffler still necks down to 2 x 2.00" on the inside. THough you've got a total flow area of greater than 3", the restriction down to 2" on both outlets will still produce more backpressure than a straight 3" through the muffler.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
staticpage;1514441 said:
buy the ebay CXRacing cat back and let us know if its any good
cx racing catback
why when you can buy it from grimsta a vendor on are site for 320 plus shipping..? i was thinking of buying that exhaust down the road to but i might go custom not sure yet...
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
Poodles;1514463 said:
Eww
Only uses 2/3 hangers, not centered in the notch in the bumper and it probably extremely loud without the silencer.
now that you pointed that out, I'm appalled.
