Hi guys,
I just started a new project and purchased a 1jz supra front clip. I comes with a 2 weeks start up warranty so I'm trying to start it in the clip and make sure everything is ok. It arrived yesterday and last night I began working on it. It has missing the 30a & 40a fusible links and the main relay so I replaced those, hooked up a battery and fuel pump. I tried starting it (by the key) and it cranks but doesn't turn over. I checked and it does not spark and I check the injectors with my noid light and they aren't firing. The ECU casing looks beat up and I'm wondering if it's bad. I can't check the codes because it has no gauge cluster. I checked and didn't see any missing connections, but does anyone have any ideas?
I greatly appreciate it,
KC
KC
