Hey guys, I just got back from being deployed over to Iraq.  While I was gone my 1jzgte Cressida starting acting up on my wife.  First the alternator crapped out, it was replaced but now the car has a pretty bad stumbling and hesitation under partial throttle and just off-idle.  Feels to me like a lean spot because sometimes it will also backfire through the intake under acceleration too.  If you are stopped and just mash the gas, it revs slower and stumbles and sometimes backfires through the intake...once revs climb a bit more, boost comes on and it pulls hard to red line like it should.  If you are just cruising along lightly touching the gas it does the same stumbling/hesitation and backfiring through the intake.  I put new plugs in, new Denso O2 sensor, battery, and checked all the connections out which all look fine.  There's no vaccuum leaks I can find anywhere and the hose going to the MAP sensor is just fine.  It seems to me like fuel isn't right...possibly timing, but I'm pretty certain I'm getting a lack of fuel at partial throttle.  I think maybe a fuel injector might be going bad.  Anyone have a good way to check the injectors out?  I had a VERY similar problem with my SR20 when one of the injectors went bad...partial throttle sucked and hesitated everywhere but full throttle was fine.  I will be swapping/upgrading the fuel pump today to a Denso 280lph pump from the Chaser pump it currently has.  Keep in mind this car is NOT a recent swap...it's been swapped and running great for about two years now with absolutely no problems before the alternator went bad.  It has stock twins, non-TRC throttle body, automatic, FMIC, 3" exhaust.  If anyone has any advice or help, I'd be very grateful!  I will be replacing the PCV valve and probably also throwing in my wideband O2 sensor, but it's not going to tell me anything I don't already know (lean spot) probably.  If the fuel pump doesn't take care of anything which I doubt it will, then I might swap out the Idle Air Control Valve that someone recommended to me could be it, otherwise I might swap the injectors with some other stockers to see if that does anything but that doesn't look like a fun job.  If none of the above works then I'll start thinking about sending the ECU to get new capacitors in it, but hopefully I'll chase this down before getting to that point since I don't have a spare A/T ECU anywhere.  I wan to get it up and going before Thursday so we can take it on our road trip instead of our 240SX.  Someone help please!!
