i just finished the swap and when i went to crank it without the efi fuse in to get oil in the turbos, it turned over fine the first time, but when i went to turn it over again the starter just slipped and then i heard it click like the gear grabbed. went to start it again and it turned over.
so then i wanted to see if the car would start after puting in the efi fuse back in, of course the starter slipped again and then it grabbed again and was able to turn the engine over, but it did not start. i tried it a few more times but it did not want to even try to start.
i checked for fuel and when i pulled off the fuel line to the stock fuel pressure reg, it had lots of pressure in it, so the fuel pump is working.
first question- is the started toast, ive never had one do this. i am not looking forward to taking it out, i had to on my 7m and it was a real pain!
second- can i use a digital volt meter to check the injectors? and what other things should i check for to get this running?
when i did use the volt meter and set at 20 i did not get any reading at all when i tried starting it. also pulled a plug and there was no sighns or sent of gas on them
just found this hideing under the intake manifold! not sure what its for or were it goes.
found it! it was a vsv by the oil filter, thanks mattsplatt.
