I'm running a 1JZ/R154 with Driftmotions 57 trim Turbo kit,JDM 2JZ 440's and Stock ECU with SAFC.
It runs Great and No problems at all except I'm pulling Fuel on the SAFC to the max (-23) on just about all Rpm's up to redline to Lean this thing out.
It Will also only go about 11-12psi w/ a 15lb wastegate Spring,with MBC set to Wide open.holds Boost Fine just not enough.
Are the JDM 440's Overkill and Why Pulling so much Fuel does it still run pig rich. 10's all the way across to redline on my wideband. No Boost Cut or anything even that rich.
Should the SAFC be leaning this thing out more?
Its def working as I can adjust it at Idle and it changes A/R's perfectly.
any Ideas? Lower Fuel Pressure below Stock?
I would think the SAFC should be fine for Mild tuning.I'm not looking for 1000hp or go standalone, just it should be way faster than this.It falls on its face at Boost.:: angry ::
