1jz Pwr steering hose
Prettyazznouka
75
NYC
T701jz;944197 said:
Reservoir filter clog...poor circulation.
How do I rectify that? I have a extra reservoir just swap it out? When I poured the fluid in I noticed a off white color start to back up.
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
did you the bleed the power steering?
Prettyazznouka
75
NYC
No Not really.... Most of the fluid leaked out because of the hole and when I disconnected everything. I dont kno how to bleed it. My 1st time doing this
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
theres several ways to do it, how i do it is use something with suction to suck out the resovoir and then refill it, turn the wheel and repeat until its fresh all around. you can either use a hand pump or even an empty soap bottle with a hose attached to it going into the resovoir.
another way is to plug the small resovoir hose inlet (from cooler), put the rack(to cooler) hose to a bucket and refill it that way never letting the resovoir getting low. IMO siphoning is the easiest method for me when i would bleed the p/s systems
