1JZ PS Pump Peice Needed
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
I don't know when or how, but the little nipple that bolts to the power steering pump on my 1JZ is missing. The piece that I need bolts to the drivers side of the pump with 2 small bolts and has a nipple on it so that the 1" line can go to it. I need this little piece ASAP!!! I have less than 2 weeks to ge this part. Any help in identifying or locating a replacement would be much appreciated. I'm pretty sure that the same part on the 2J will work, but I don't know what the part is even called. Thanks all.
Adam
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
is it this?
your pics are too blurry for me hehe (this is the 2j pump btw)
tlo86
Jul 24, 2005
3,914
Colorado
TaSe said:
IAC? idle air control valve or something of that nature? Blk part with 2 nipples on them?
thats what im trying to figure but i think he means the 1'' return from the p/s pump?
tlo86
Jul 24, 2005
3,914
Colorado
than that should be it in the picture, not whats centered but to the top more the treated metal fitting. the other is the high pressure line (with the valve) to the PPS and then the line goes from that to whatever cooler you choose to use and to the resovoir
aphxero
787
Seattle, WA
Man it's just an m8x1.25x20ish bolt. If youre really worried about that I'll give it to you. I just like helping people with my junk I don't need.
fstlane88
Single time!!
South FL
I actually have one...I broke both of the nipples...long story. But I have one, I JB welded two vacuum nipples I had in a assortment pack on, held fine, it's not really something that sees movement so it shouldn't matter.
I removed when I put on DM's high pressure line as it doesn't have a provision for that valve. I'll give it to you, just pay for the shipping.
Or if you rather fix yours JB weld works fine, it's just kind of a PITA to hold that nipple in place long enough for it cure enough that it will hold itself.
tlo86
Jul 24, 2005
3,914
Colorado
TaSe said:
Do you know where i can get that valve? I broke 1 of the nipples=/
toyota im sure has it Lol but jb weld should work although i dont like that stuff.
fstlane88
Single time!!
South FL
It's not pretty but it worked, and you don't need the old pieces just be able to stick a vacuum nipple into the valve a pic of my old setup...
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
The powersteering pump itself is interchangeable from ANY JZ series engine from any market any year. The things that bolt onto it is what makes it model specific, and all those parts can be purchased at any local toyota dealership...
I hope that answers your question
