1JZ oilpump and pick up on 2JZGE block?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
thats not me its 'csnow'
hahahha
yea i was hoping they were the same pump atleast different pick though? hmmm
The Reaper
Jan 10, 2006
1,909
Florida
i know the pans are the same on 2jzgte and 1jzgte but are the GE's front or rear sump? rear i would imagine so why would the pumps be different?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
the 2jz-ge comes in both mid and front sump depending on what you got it from. i know that the jza80 has a rear sump.
aphxero
787
Seattle, WA
Well, I have a mid sump 1j with in my car with the pickup and pan from a front sump 2jzge. the oil pump fit the same on both.
The Reaper
Jan 10, 2006
1,909
Florida
well mid sump and rear sump are the samething
so that means the 1J oil pump should work with no problem then....
thanks man
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
I don't see why it wouldnt.
front
gs300 2jzge
aristo 2jge/gte
chaser 1jzge/gte
is300 (i think)
rear
jdm soarer (95+) usdm sc300 (all years) 2jzge
jdm soarer 1JZGTE all years
supra 2jzge and gte
tissimo
Stock is boring :(
Melbourne, FL
Is mainly asking if the 1jz oil pump would fit on a ge..
I dont see why it wouldn't the 2jzgte oilpump is the same and a replacement off a 1jz oilpump correct? and the gte pump bolts to the ge block (countless built ge blocks around under gte heads)
The Reaper
Jan 10, 2006
1,909
Florida
yea im not worried about the pick up and pan
im talking about the actual pump. will the 1J pump bolt in and work like factory?
Ken
350
Houston, TX
1jzgte and 2jzgte pumps are the same. are you planning to put a used 1jz pump on a 2jz block? they are about $150 at the dealership with a discount, so it's best just to get a new one.
The Reaper
Jan 10, 2006
1,909
Florida
well i figure my 65,000 mile motor's oil pump is pretty decent i mean i would have to be. but if its only 150 i guess i could
RacerXJ220
Interdimensional
Abalama
Yes it will work. That's exactly what I did. I swapped the 1J and 2J-GE pumps, pickups, with the pans. No issues. Changed it from Front sump to mid/rear.
