yea so i juss finished my single turbo conversion and everything is in place ready to start. i try to crank and the starter doesnt even click, only thing i am getting is a click from the inside which i always got. all the grounds are in the right place except for the ground that is on the same harness as the power wire that goes on the starter.
at first i placed it anywhere on the engine bay, but after searching i found out it has to be on the engine block. can anyone tell me the spot on the engine block it has to go. Or can maybe take a pic of where your ground on the engine block is? also can i put it on the intake mani? im pretty sure thats the problem cuz thats the main ground for the starter to get power, and needs to be on the block instead of the engine bay.
