I have a pestering misfire that has progressed, I am puzzled and am in need. I own an 89 NA to 1jz convert. It has an AEM v2, Bosch 750cc injectors, upgraded rail and pump. I have an extended wire harness that was checked and is good. Fuel pressure is good, coils are well insulated, not sure where to go next. The video on the youtube link shows the misfire. The picture are my plugs (left to right is 1 to 6). I have gone through 3 sets of properly gapped plugs as well. The misfire was scarce when the original tune was being done and only happened while the engine was warmed up. Now it misses on startup. I believe my Duracrap battery is just not holding the power well and the result is a weak signal to the injectors from my battery thru the ignition switch but I have not checked it yet. It has been sitting for a few weeks at a time for a while now so I have had to charge the battery to run it each time. Does anyone else have any ideas of what is going on? Any help is greatly appreciated.
Thanks,
https://youtu.be/Id3DBLq1uTM
Thanks,
