1jz injectors not firing....HELP!!!
87supraguy
808
Tucson, az
Tomorrow I'm going to try to start running more test... I'll check IGF in the ignitor, also the crank and all other sensor to make sure they're communicating With the ecu
IBoughtASupra
4,455
Queens, NY
Check IGF at the computer first how I described in the PM. If nothing, then check the igniter since you can get a signal at the igniter and none at the ECU which would indicated a broken wire. So checking at the ECU first, eliminates doing both steps.
87supraguy
808
Tucson, az
aphxero;1666165 said:
I'm only gonna say IGF one more time. Check the wire. If the ecu doesnt see the confirmation IGF signal it doesn't turn on the injectors. Seriously check continuity from the igniter to the ecu. If it's good check for a pulse on it. No pulse is probably bad igniter or possibly ecu but I seriously doubt it. I've dealt with this numerous times so I'm speaking from experience here. I'd be surprised if it's anything else.
If crank sensor wasnt functioning you'd get no spark period. period.
cheked the IGF at the ecu and it is getting 5v
87supraguy
808
Tucson, az
Sorry guys had somethings come up and had to stop working on the car. But to answer your question I Was checking with a multimeter so it wasn't able to read any pulses I'll test it with a test light for the pulse. If that pulses then I'll start test continuity from sensors to ecu. I just hope I find the problem.
aphxero
787
Seattle, WA
Well if you have spark then the ecu will have enough info to fire injectors. The only requirement to get injector signal on top of spark is IGF pulse and sta/nsw.
87supraguy
808
Tucson, az
found my issue, the wires on the rear cam sensor were repinned backwards, i didn't know that the cam sensors polarity mattered but i guess it does... car starts and runs but breaks up at 2k and now i'm getting codes 14, 21 and 78 i'm about to looks these up.
87supraguy
808
Tucson, az
the wire tracing and all i did was re-pin it correctly and good to go! but now i'm having these new issues but still a drastic difference.
87supraguy
808
Tucson, az
latest problems have been solved!!! it was 2 of my coil connectors that were effed up and i just made sure the pins were going in to the coil correctly and after that, she was pulling hard.
