1jz ignition map help
kilo_gulf
12
Nassau
almost finished my 1jz/r33 project and need some help with my ignition map, I've looked at a couple of threads to see what type ignition timing people are using on their motors and constructed tne following map. any advice would be appreciated.
[/IMG]
the turbo i'll be using is a t3/t67 with a stage 5 turbine wheel (t350) I know the turbine housing is abit on the small side so I purchased a JGS 50mm wastegate. I want to make around 400whp on 15psi with 87 octane (i live in the Bahamas and nobody seems to have a clue what the rating is so i'll plan for 87)
500whp with 20psi and methanol injection
tissimo
Stock is boring :(
Melbourne, FL
Timing should increase after peak torque (around 4500-5000 on stock cams)..
and for 15 psi on 87 octane, I would start out with 14 degrees around peak and end up around 16 @ 7500 or so.. that should be pretty conservative to start with.
Thatll get you started and then go to a dyno and tune it out.
