1jz idle air valve gasket replacement???
Does a 2jz one not work?
Could also just use a little bit of fipg on both sides of the gasket.
Maybe your right.
Then I think a 7m will work.
I've seen someone use a different one somewhere. Forget what tho.
You can reuse all the metal gaskets. Mines been off like 4 times. Still works fine.
Same for intake and turbo and the metal coolant gaskets.
