1jz-gte questions
What's wrong with the hydro fan? I hadn't planned on changing to an electric fan. Do you know something about it that I need to know?
Turbo 7M said:
yes i agree with annoboyingr clutch, timing belt, front and rear main seals, radiator, and i would say decide weather you want to keep your hydro fan or you want electric fans, and if you go electric you would also want to change your water pump to a 2jz one. i strongly recommend changing those parts too because you will endup changing them out later on most likely. speaking from what i've seen and learned.
This is why I asked.................:dunno:
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Brewsters right It is like a huricaine lol
but it's great. I would not give up that hydron fan for anything. Especially when it come to keeping my engine cool. something that works great, compaired to smething people say is ok or can hadle it. Just doesn't cut it for me
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
convert the motor to mechanical or electrical fan
pull your harnes through the speed hole instead of extending it
upgrade the Y pipe or go single while the turbos are accessable
buy your engine from driftmotion or C&T japaneese engines ontario ca ask dennis for a good deal tell him how i kevin bought a clip from him. also every one is SoCal pretty much buys there import clips from him his number is 909-923-5588 he provides engines for proto ctunes sp a ton of car shops in the area.
