1JZ-GTE Ecu plugs for patch harness
_EiKNARF_
1JZ, NO S@*T!
Aug 20, 2012
Lewiston
I just bought a 96 mitsubishi galant ecu off ebay for 30 bucks. Uses the same plugs. The only problem is you cant release the pins from the connector. Not really a problem so to speak, just makes soldering more tedious.
Krister
Holset lover
May 2, 2005
159
Finland, Europe
Thanks for the replies. So it looks like the Galant ECU is the same as JZA70 and the Ford Probe is the same as JZZ30 Soarers? Am I correct?
Can the Ford Probe connector be bought seperately some where as an aftermarket / oem part? There are companies selling patch harnesses, where do they get the connector?
the toyota 1mzfe engine uses the same plugs as well. thats like old camry. idk what you guys have in europe but there all over here in the junkyards.
old hondas and acuras use the 2 row as well.
toyota 1mzfe engine uses 4 row like soarer and chaser.
