1jz flywheel bolts?
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
driftmotion sells a ARP flywheel bolt kit. i am using it on my 1jz flywheel on my 2jz
NgoFcukinWay
Formerly Got Boost?
Apr 3, 2005
493
Houston, Tx
if it's the same concept as their other bolts/stud kits, then they're stronger and aren't made to stretch over time. That would be my guess.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Just get a 2JZ bolt kit. 1JZ and 2JZ, 7M, 4A, all use the SAME BOLTS. It's just a question of how many there are.
I've used 2JZ kits on 7Ms, and on 1JZs personally. Remember, 1JZ flywheel = 2JZ bolt pattern.
tlo86
Jul 24, 2005
3,914
Colorado
they are only 30$ for the arps Lol and work fine
factory 2jz install you have to stretch the bolts when installing and you cant reuse them (or at least you are not supposed to...)need to turn the bolts an extra 90 degrees after you torque them.
