Well I did not pass Arizona emissions tonight.
HC Failed - 2.5 against allowable limit of 1.6.
CO Failed - 53.19 against allowable limit of 15.0.
NOX Pased - but barely (2.47 against limit of 2.5).
Visual Inspection OK -- Go Figure?
Obviously running rich. I'll need to lean out a bit.
I'm running
91 Octane Fuel
1JZ with stock twins
440 injectors
Stinger EMS
New High Flow Cat
New Tanabe Hypermedalian Exhaust
Comments on where to start? Successes or Failures that you've experienced.
Thanks
I'm running
91 Octane Fuel
440 injectors
Stinger EMS
New High Flow Cat
Thanks
