1jz electric fan question
boosted4life
Wyoming
I was going to put an electric fan on my 1jz supra but ive never done it before and I wasnt quite sure where to wire it into. Any suggestions? pictures would be great!! Thanks!!
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
86 goes to the on/off switch or temp switch
30 goes to the battery (use a fuse)
87 goes to the fans
85 goes to the ground
figgie
Twin Cities, Minnesot-ah
Ok before you do that.
Why exactly are you installing an electric fan when the OEM hydraulic fan is leaps and bounds better than any electric fan on the market?
boosted4life
Wyoming
because the dumbass "toyota mechanic" that owned the car before me removed it and threw it away.
2JZ_MA70
191
Cleveland
Look into the Flex-a-Lite Dual fans with integrated controler.Very nice product and it has separate temperature sensor and relay. It it progressive controler starts at 60% flow and increases if temperature doesnt drop. It can be adjusted to come on from 160-220 I think... I have mine set at 195. It is expensive but very nice unit.
boosted4life
Wyoming
do you know about how much those run? thanks.
boosted4life
Wyoming
92TealSupra;1140563 said:
Why don't you find the hydro fan? Just take your time you're bound to run into one, and i hear they are about 8x better then electric fans.
i dont even know where to look or how to install one. any ideas?
