1jz ECU's
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
yah i know that..i know i think the chaser harness and supra harness are completly different in plugs..but i see some soarer ecu's that have the same plug as supra ecu's...so are they compatible? i know the chaswer ecu wont work cause the plugs are different
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
they all have different plugs on the ecu side, but all will work if you switch the connectors or use a jumper harness, you can even use a 2jz ecu with a jumper harness
S.A. supra
2,405
Buda, Texas
You threw me off when you asked which ones are compatible with a supra. Just find out what engine and harness you have and buy the ecu that goes with it, and call it a day.
