1JZ ECU pinouts WITH colors Enjoy JZA70 ECU-
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
So It took some times to do this, but every wire has been check, and color codes. SupraDupra has made the picture you're looking at. Online there are a lot of these pictures, but they're never complete. I wanted to give color codes to, as I feel they're just as important as knowing what each pin does. Many harnesses that people get come with broke plugs, or cut wiring. At least now you can start ahead of the game by knowing the colors.
Enjoy anyone, if you have any questions PM or post on this thread:
X
1. Pink / Blue
2. Light Green / Red
3. Blue
4. Red / Black
5. Blue / Red
6. Green / White
7. White / Yellow
8. Red / Black
9. Green / Yellow
10. Green / Black
11. Medium White / Red
12. Medium White / Blue
13. Medium White / Black
14. Green
15. Gray
16. Yellow
17. Red / Blue
18. Yellow
19. Red
20. Red / Yellow
21. Red / Black
22. Red / Green
23. Red / White
24. Medium Brown
25. Medium White
26. Medium White / Black
W
1. Blue / Black
2. Green / Black
3. Teal
4. Green
5. White
6. Clear
7. Red / Green
8. Yellow / Black
9. Brown
10. White / Red
11. Yellow / Blue
12. Xxx
13. Yellow
14. Clear
15. Blue
16. Black
U
1. Blue / Yellow
2. Xxx
3. White / Brown dots
4. White / Blue
5. White
6. Blue / Yellow
7. Yellow / Blue
8. Green / Black
9. Red / Green
10. Orange / Blue
11. Orange
12. Blue / Green
T
1. Black / Red
2. Black / Yellow
3. Black / Orange
4. Gray / Green
5. Red / Yellow
6. Brown
7. Blue / Red
8. Pink
9. Gray
10.Xxx
11.Black / Blue
12.Black / Red
13.Medium Gray
14.Green / White
15.Red / White
16.Red
17.Black
18.Red / Blue
19.Orange
20.Green / Orange
21.Xxx
22. Black / Yellow
V
1. Pink
2. Xxx
3. Xxx
4. Red
5. Xxx
6. Blue / Black
7. Brown
8. xxx
IBoughtASupra
4,455
Queens, NY
The "A/C control" pin is for idle up?
On the 1JZ, the compressor clutch is controlled by the ECU or the AC amplifier? Aaron told me on the MA70, all the AC controls go through the AC amplifier so even with a standalone on a 1JZ, the AC compressor should still turn on, assuming the pressure switch and freon is present and in spec.
92TealSupra
Sep 2, 2008
1,585
Great Lakes State
It looks to me that with a stand alone on the 1JZ A/C will still work. The Idle up may not though? let me look into that. Ill find a wiring schematic and see what is running where. It would make sense for it to go through the A/C amplifier, then send a signal to the ECU to idle 100-300 rpms more.
good question.
