1jz DDP?
marks332
85
Yorktown, VA
Does anyone know A place that sells divorced downpipes for the 1jz's? BIC had one that only bolts up to the CT26 turbo on the 7Ms. Do they make 1jz DDP's? Thanks
It would have to be for the Vvti 1j or a small single with internal wastegate like the 57trum ct kit that dm used to sell. Not many people do that.
An not enough room to do a ddp on the stock twins.
Varriable valve timing intelligence.
If you have stock twins and your motor looks like just about every other 1jz you don't have it.
Vvti uses a single turbo. Non Vvti uses twins and it's a tight fit.
If you want to know more Wikipedia search Vvti and 1jz.
te72
Classifieds Moderator
6,619
9
WHYoming
I would only argue with you on account of having seen one in the FS section about a year ago, was a member in Australia, if I remember correctly. Would definitely make for a tight fit, and I suspect it may have been a one-off, or limited run. Might still have pictures of it in the JZ parts for sale section, if you can find the thread...
I remember that. Thought I was for the 2jz tho. Maybe not. Think it was homemade for sure tho.
It's possible but a lot of work and most people go single anyways once the twins go.
