1jz dash harness plugs?
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
I was looking at my 1j's harness and are these the dash plugs you have to wire up in to the dash harness? Or are there more? And looking at my ECU I can't tell if it came out of a supra or a soarer, can anyone tell?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
doesn't look like a soarer 1j, might be a supra 1j from looking at the ecu but where is your oil sump located at? front or towards the rear?
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
yeah from the plugs pictured it looks like a jza70, another way you can tell is if it came with a mechanical fan.
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Awesome.
Thanks guys. I really appreciate the input.
Are these the plugs I have to wire into my 89,MA70 dash harness? Or are there more?
And also, can anyone post a couple links to diagrams and how to splice the harnesses together? I don't plan on extending it. I'm drilling a hole below where the speedometer comes through the fire-wall.
tissimo
Stock is boring :(
Melbourne, FL
those are the harness plugs, and being an auto wont make it more difficult to swap it (i assume you're going 5spd now?) If so you will just have more wires left over (the wires going to the Trans ecu)
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
The supra has already been swap to 5-speed, but I need some help with what wires go to what pin out on the plugs.
If some one could give me some links it would awesome.
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
I'm pretty sure that I've got this down now it shouldn't be hard at all.
Will the fan computer connector, plug in to the MA70 fan computer connector plug?
tissimo
Stock is boring :(
Melbourne, FL
the hydrofan ecu connector is the same as a ma70 body connector,yes
mk3 bamf
The Red Dragon
Jan 31, 2007
229
washington
Oh dam it, I thought that the plug with the blue wires was for the heater fan.
But it's for the hydrofan so I don't have to worry about it then.
Can I just take out the wires from the harness that go to this plug because I'm eliminating to hydrofan?
Thanks in advance,
Scott
