1jz Crank Pulley Removal.
Status
Not open for further replies.
Turbo Habanero
4,229
Tucson,AZ
So I got the crank pulley bolt off now just need to know any tips or if there's a key of some sort to take off the pulley I
it self without damaging it.
Thanks for any help.
Turbo Habanero
4,229
Tucson,AZ
So I went and got a crank pulley removal tool.
Used the 8x1.25 bolts to pull it out.
But the crank pulley tread size is to big for the tool.
I'm confused.
You don't use the crank pulley bolt threads when removing with a tool. There supposed to just slide off tho.
When you use the tool you use the flat piece with the 4 slotted sections and thread the bolts in through the slotted section where they line up. Then the big bolt that come with the kit goes in the middle of the flat piece and then there is a cone piece that goes on that and stops at the crank snout. Turn the bolt in and the that will pull the flat piece and the crank pulley attached to it off.
url
Status
