1JZ Compressor Surge!!!
Dejvid1785
Boostaholic
Jan 27, 2008
99
Cumming, GA
I just finished up my swap and i'm running a 60 trim ct 26 on my 1j motor. I have an aftermarket FMIC with hard pipes. Currently i'm running just a downpipe until i get the car to the shop so i can finish my exhaust. I'm running a greddy type R BOV. At idle when the engine is revved the BOV does not go off and you can hear the surge, under a load you can hear the bov but i think there is still some surge. The vacuum lines are hooked up on the bov. Is there certain vacuum lines that i should use? I don't why the BOV is not doing its job and i don't want to drive the car when this is happening. Any help is appreciated.
Dejvid1785
Boostaholic
Jan 27, 2008
99
Cumming, GA
Its really close to the throttle body, well here is a picture of it.
carguy34
Denver, CO
I had that BOV on another car (RX7) and loved it. IIRC a post TB vacuum line needs to to hooked to the top nipple and a line from near the compressor should be hooked to the bottom. Is that how you have it? Sorry I don't know enough specifics about the 1J yet to referrence exact vacuum sources. Good luck, that BOV is awesome when it works correctly.
Dejvid1785
Boostaholic
Jan 27, 2008
99
Cumming, GA
Well i just ordered the soft spring meanwhile i had this knock off greddy type s at home i tried running that and i'm still getting surge. When you say run a vacuum line from near the compressor where exactly do i run one from?
Turbo Drifter
534
Surrey, BC Canada
That would be anywhere post turbo and pre TB, you want a source that dose not see vacuum only boost.
Big BOV's like that are known for slow response, and more so at low or no load. If you had it on the street and got over say 6psi boost and backed off it would work properly.
You need to make sure that you have it set up right though or it will surge. Make sure you have all the lines hooked up right and that the lines are not too small. Find a vac line diagram for hooking up that BOV and should be fine. You want to adjust it so that when driving once you back of you do not get any chirps of compressor surge. But tight enough that it stays closed at idle and no load. With a BOV this big at lower boost they can be hard to set up.
On my Tial 50mm I got the biggest Vac source I could find and put the lightest spring in it to get rid of compressor surge.
On a side note be very carful of that 60 trim upgrade CT and compressor surge. The wheels is already pushing the limits of shaft size on that unit and surge will just make it worse.
Dejvid1785
Boostaholic
Jan 27, 2008
99
Cumming, GA
I been trying to find a install guide online for that type r but i'm having no luck. If someone knows where i can find some info let me know. thanx
tissimo
Stock is boring :(
Melbourne, FL
You might need a stronger (bigger) vacuum source. On my alltrac, the tial wouldn't open hardly at all until I tapped into the Brake booster vac line and T'd it to the Tial, it opens just by reving the car now.
Dejvid1785
Boostaholic
Jan 27, 2008
99
Cumming, GA
So you're saying tap into the brake booster vacuum but that vacuum source comes from the intake manifold also i can't why there would be soo much difference.
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
So if my BOV is open at idle that means its wrong? I'm confused now. I don't have much less vacuum at idle than when i let off the full boost. It's about 28lb at maximum after boost and about 23-24 at idle. So in this case should it be closed at 23 and open at 28?
tissimo
Stock is boring :(
Melbourne, FL
Worth a shot maybe? On the 3sgte there are limited vacuum ports so the one I tried was T'd off a couple times all ready and just wasn't strong enough. The 1jz has several vac ports off the Intake manifold, so try to use the larger vacuum port and size it down (if needed) right before the BOV its self.
Turbo Drifter
534
Surrey, BC Canada
At idle there is no boost pushing on the BOV, the pressure in the Intercooler piping needs to be taken into account. On a MAP car you can run with the BOV open but you run the risk of sucking crap in it.
I hope this makes sence.
Jeremy
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
Jeremy
YEah i think it does. I never realized that when its open at idle it sucks it all in. I guess i was confused by the purpose of the BOV to blow the pressurerized air out. So if i have a Blitz Bov with the SUS filter attachment it should help with this situation right? Thats why they included it. Thanks alot
Pernilongo
LADA is my daily
Jul 15, 2007
446
Los Angeles
It looks like my spring it too weak to hold the amount of vacuum i have. This Blitz BOV spring is rated only at 17 lb max. It is always open, i tried to adjust it for hardness but still with no results. The only thing that helped was to block of the low boost port. only then it doesn't leak.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
10secdream;1112901 said:
:aigo: Wow that turbo did not last long at all. What did you do to fix the problem?
I removed the spring from my SSQV so that it opens easier. This allows it to vent more air when running mid-boost.
The proper way to handle it would be to install a 2nd BOV.
1JZS13
BROCAL-SOCAL
ouch. its luck of the draw on turbo life with compressor surge.
i had a ebay turbo run strong for 1yr and 4 months almost. then another one blow up in 5 mins. AHAHAHA.
