1jz camshaft torque?
Tim
regular member
Oct 16, 2006
272
CA
I'm installing cams into my 1jz and I was wondering if anyone knows the factory spec on the camshaft cap torque in" in-lbs."
For the 1jz I read somewhere when I did mine and it was 12lb. I thought that was low, but that's what I read. Good luck.
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
It is 14ft lbs, but it is not just a 'put them in and torque 'm down'. There's a sequence of three turns you need to follow to properly install them, all bearing caps are also installed in a certain order.
Download the 2jz tsrm and look up 'Engine' page EG-65 and further.
