1JZ Cams Question
The intake side will have cam sensors on it.
Actually they aren't cam sensors, but it will have two protusions on them that line up with your cam sensors..........sorry, I don't know what they are called.
I can't remember, but I also thought they had an "E" stamped in for exhaust and an "I" for intake, but don't quote me on that.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
supra_kid101;1293617 said:
I've been looking for an I or an E but no luck so far. So the little notches between the lobes on the one cam are for sensors?
yea there should be 2 small notches for the cam sensors. one for the front cam sensor and one for the back cam sensor
pmpdaddyt
No sup, just Soarer
Jul 14, 2008
9
Maryland
hey supra kid hope u dont mind me thread jacking a little but....
what are the largest cams u can run on a stock 1jz?
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
stock head... or stock twins? stock everything? You will see no benefit running anything larger than ~264's on stock everything. Any more than that and you're just killing spool for no power gains.
tissimo
Stock is boring :(
Melbourne, FL
pmpdaddyt;1296140 said:
just a stock head
Stock Castings or bone stock head (stock springs, etc)?
Stock casting, very large I'd assume. Probably ~ 11mm of lift before you'll have to starting thinking about machining the head to fit the lopes
Bone stock head. I wouldn't go over the Crower 264s (8.7mm lift)
