1jz build up help
AZN MK3
341
Now in the U.S.
ok... now that i have my engine... right, i want to know if you guys changed anything on the 1jz engine meaning seals, to plugs and waterpump???? and what else should i look forward into changing before i actually drop it in my car??? also how much psi's is the stock 1jz pushing out of the twin's???
OneJoeZee
Retired Post Whore
aboard the Argama
If your engine is out of the car, go ahead and get yourself a gasket set and replace all the important seals and gaskets while they are easy to get to.
It would be a shame if your RMS started leaking shortly after dropping the engine in.
stock boost is around 9-10psi or so.
AZN MK3
341
Now in the U.S.
thanks.... ummmm do you guys know where's a good site or place to buy the gasket set... or do you guys know if driftmotions have the gasket set too....
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Champion Toyota (on SF) sells a gasek set.
I neglected to change my rear main seal, now it's leaking :(
Oh, it's a lot easier to change the turbos with the motor out, so I suggest throwing a single on it before you put the motor in :)
AZN MK3
341
Now in the U.S.
why is that???? doesnt the twins push enough as it is stock??? well im i was just lookin to do a stock 1jz set up... unless you guys think other wise..
SupraStardom
181
Council Bluffs, IA
Driftmotion sells thermostats for like 22 bucks. They sell the front and rear main seals too. They have timing belts, but you can go to a auto parts store and get one. I think it was something like a 88 izuzu trooper 4.6l (I think don't quote me, search the forum).
annoyingrob
Boosted member
Jul 5, 2006
2,304
Timing belt is the same a a 2.6L I4 Isuzu trooper, around 1986 IIRC.
I just suggested you swap out the twins because they will blow eventually, so you might as well upgrade now :) Seriously though, you can run the stock twins if you want.
AZN MK3
341
Now in the U.S.
ok... thanks man... ummm the one main biggest concern that i have is should i get an overhaul engine gasket kit or just change out the rear and main seal??? or if you can tell me what like the biggest defect i should worry about...
tsuper92
supra addict
Apr 7, 2005
1,376
mass
really just the seal's need changing,front seal,rear main,and possably cam seal's.all the rest of the gasket's in the motor are metal type shim gasket's that don't fail easy.you might want some new valve cover gasket's too.
AZN MK3
341
Now in the U.S.
ok thanks.....
