1JZ Belt No A/C
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Take a piece of string, run it around the accessories to the length of the desired pulleys, remember to make it a little shorter than your measurement for the belt tensioner.
Take your length, in millimeters, and add it to the end of the part number.
Your number should be K060xxxx or something to that effect. The last numbers are the length. If you know the people at the parts store, they will allow you to "borrow" (potentially) a couple to try.
Bigzavs;1517594 said:
its just the stock JZ smooth pulley
oh ok the reason i asked was because i was running no a/c or p/s and that required me to run a ribbed tensioner pulley. so i guess ill have to put the smooth back on.
And just for reference the part number listed above that was posted by BIGZAVS is the same part number as the 2000 Audi W/2.8l
