1jz aftermarket oil press gauge see pic
JP85MX73
79
NY
is this the right thing to unscrew?
JP85MX73
79
NY
great! I already have an adapter from driftmotion. whats standard pressure on the 1j? 40psi~ idle 70~ cold
OneJArpus
2,798
I can't remember but i think 70 cold 35-40 warm 70+ cruise 3k.
I see 80 psi cold, 40 idle and 80+ at 2K (near 120 on stock gauge but not exactly on 120) this is on a 1.5jz swap not sure if it makes a difference
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
what weight oil are you running? those numbers seem awfully high.
I'm around 80psi cold, 40-50psi cruising, and ~20psi at idle.. I have checked and re-checked this in regards to others and have found these to be the proper pressures.
10w-40 1JZ.
