Not sure if any one has already posted this, but here are the torque specs for our engines can we put this where it won' get buried
all torques should be in several passes
- head bolts = 25 ft lbs mark ft of bolt and go another 90 x 2, 180 degrees total
- connecting rod caps= 22 ft lbs mark and go another 90 degrees
- main bearing caps= 33ft lbs then mark bolt and go 90 degrees farther
- cam bearing caps= 14,ft lbs in three passes
- inner timing belt cover= 78 in lbs
- cam gear bolts = 59 ft lbs
- valve cover bolts = 74 in lbs
- inner intake manifold 7 bolts =20 ft lbs
- fuel inlet pipe= 30 ft lbs
- exhaust manifolds 29 ft lbs
- turbos= 40 ft lbs
- rear main seal plate 6 bolts = 52 in lbs
- upper oil pan #1 oil pan 22 bolts/12mm bolts= 15 ftlbs,14mm bolts= 29 ft lbs
- turbo outlet pipe 2 nuts= 20 ft lbs
- oil pan baffel plate 5 bolts,2 nuts= 78 in lbs
- oil pickup = 78 in lbs
- #2 oil pan lower pan 16 bolts 2 nuts= 78 in lbs
- oil pump 9 bolts 15 ft lbs
- inner water pump housing= 15 ft lbs
- water pump 15 ft lbs
- flywheel M/T 8 bolts 36 ft lbs then mark bolt and go another 90 degrees
- flywheel A/T 8 bolts 61 ft lbs
- turbos= 40 ft lbs
