1J will not stay running at idle
macjac69
274
Mississippi
Have a 1J with a stinger, car has had the cold start issue but now it will not idle on it's own. As long as you hold the pedal down in high Rpms it runs release the pedal and it dies out. What should I check first?
Mike, does it go lean and then cut itself off? Does your wideband go to 17 and then it shuts off? I bet you're going to have to add more fuel.
