1J swap: what do you loose without the clip?
ronnie4
136
Huntsville
Getting ready to do a 1j swap, planning on making my own custom intercooler piping. However, would there be anything else that I would need that the clip would come with that a complete engine would not? I know a lot of this will vary by seller, but what have your experiences been?
igniter?
map sensor?
o2 sensor?
Yes, I searched
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
igniter?
map sensor?
o2 sensor?
Yes, I searched
didnt search very well.. try again.
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
igniter?
map sensor?
o2 sensor?
Yes, I searched
If you just get an engine set, this usually includes :
engine ( complete with all sensors/ignitor/coils etc)
tranny
harness/ecu
Motor brackets/mounts
Stock downpipe - ( maybe )
Ofcourse make sure you get one from a JZA70 or else the mounts may be different as well as the oil pan.
What you may lose out on is the reservoirs for the hyrdrofan ( if you need it)
Power steering reservoir if your seller does not include that.
Hydrofan seup/radiator etc.
Intercooler and piping ( but most people use aftermarket)
If you are going to use electric fans or 2JZ fans/water pump setup and using your own IC and piping, then just get a motor set.
I' really haven't seen much else that you can use out of a clip itself except for the engine, harness, ic and piping abd and reservoirs and afew nuts and bolts.
However, depending on what clip you get, it can/may come with some after market goodies but that is just chance.
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
igniter?
map sensor?
o2 sensor?
Yes, I searched
As stated above If you get an engine set there are a couple other things to like throttle cable, power steering line, power steering resivior, depends on the engine set you get aswell, if you get a soarer engine set you need motor mounts, the list keeps going, If you had a link to an engine your looking at then maybe we can help you out alittle more.
ronnie4
136
Huntsville
The 7m reservior won't work? I have an '88 so I plan on buying the BIC motor mounts anyway, so are the aristo mounts still a problem?
Planning on getting something like this:
http://cgi.ebay.com/ebaymotors/Toyo...024QQitemZ370017507394QQrdZ1QQsspagenameZWDVW
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
hopefully it doesnt have rodknock for 850$
aristo brackets wont work, the round mounts will if you cut the little tab off of it they are exactly the same as the 7m's/jz's
and the 7m resovoir will work
ronnie4
136
Huntsville
Yeah I just posted that one as an example. Are you talking about the round BIC mounts?
suprastanger507mgte
Hayward , Ca
I used the 7m reservoir when I did my 2jz swap jst like Tlo's.
You can use it the same way for the 1jz swap if tou don't get one with the engine.
The NA PS reservoir can be used for the Hydrofan as well. ( Omit this if you are using electric fans or 2jz fans)
You will need the jza70 brackets or get one from BIC. Then you can use the stock 7m round mounts ( rubber ) if you have an 89 + or get square brackets and mounts from BIC for prior to 89 years.
ronnie4
136
Huntsville
That's what I thought, it's an '88 so I will Pic up the BIC's. Since I need them anyway, does it matter what mounts come on the engine?
suprastanger507mgte
Hayward , Ca
Not really. The type f mounts that will work with your car is determined by your subframe, and in this case, you have square ones ( the rubber part) . Just get the BIC ones and they will fit fine. If you end up getting a set with your engine, sell it off and get some money back.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Everything came but the hydrofan stuff in my case. If i were to do it again, I wouldnt get a motorset and I probably wouldn't have gone 1jz. I should have gone 2j from the start, lol.
tlo86
Jul 24, 2005
3,914
Colorado
i feel i shouldve went 1j heh
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i got everything but the hydro fan assembly. wasn't a huge deal to me got a deal for like 120 shipped for Rad. fan, shroud, one of the lines. had a HP line made for 45 bucks and used my hondas PS res. for my hydrofan res. and bought a Hydro fan ECU off of Driftmotion for 50 bucks and was done
STREETOPTIONZ
Toyota LOVER
Feb 1, 2008
10
Pennsylvania
Now thats what Im talking about....UNITY, its all good to use Honda parts, hell try to fit some Nissan parts in there too lol.:biglaugh:
The Reaper
Jan 10, 2006
1,909
Florida
hell it worked and it was free and i didn't have to wait 2 weeks for shipping and trying to find one from someones clip that they'd prolly end up using themselves :)
works fine
in my sig its the little res. on the right with a red cap..
ronnie4
136
Huntsville
Cool, thanks for all of the help guys. I'm trying to make a list of everything I should ask if the clip includes before I buy the motor.
SO far I have:
Downpipe
PS reservior
MAP sensor
o2 sensor
igniter
Anything else?
tlo86
Jul 24, 2005
3,914
Colorado
SO far I have:
Downpipe
PS reservior
MAP sensor
o2 sensor
igniter
Anything else?
i honestly wouldnt worry about the top 2 but yeah thats right. and ECU and uncut harness
OneJoeZee
Retired Post Whore
aboard the Argama
If you're not familiar with JZ swaps, you should get a motorset or clip.
Some people who have done a few can start with much less and put together a running car but that's because they're very familiar with the swap, all the little small things, and were to source parts pretty easy.
