Hello, I'm in the middle of swapping a 1j into my 87 na. My question: My 1j is an auto so is my donar car, but the 1j doesn't use a speedo cable. Wondering what others have done with there swaps.
Wow I thought this was deleted. After some help it is found out to use the auto 1j trans you will have to wire in an elec speedometer, cause to shift into 4th the ecu uses the elec speed sensor( where the cable would normally go) I used a voodoo elec speedo works great.
My speedo isnt on the top of my list of pririties at the moment, but I might have to ask for some more help on this later on...
Im using an analogue dash with a digital dash loom if that makes it any harder (well im trying to use)
