1j Motor flush
ebondragon87
64
Aurora, Colorado
If you are talking about just the addative you buy and add to your oil before a change I would say no because its a turbo'd car. If you have access to an actual motor flush machine that can purge out the cleaner then maybe. The add just thins out the oil alot so it may harm the turbo's.
Frank Rizzo
478
Fixing your girl's car
THE1JZSPECIAL said:
I need an opinion on ''Motor flush''
It does just like it says, it's like flushing your motor down the drain.
THE1JZSPECIAL said:
does it work?
Depends on your definition of work.
THE1JZSPECIAL said:
is it safe?
Yes, it is safe. It won't harm you if you use as directed.
THE1JZSPECIAL said:
I'm thinking of trying it
Go for it and let us know how you make out.
