1J and 2J ECU compatibility???
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I know you can do it the other way around...
EDIT: Meant using the 1J ECU + harness, not hybrid harness ecu deal.
mobes
Supras are never 'done'
Bozeman, MT
You could, but you'd want to run smaller injectors or some sort of fuel control because you'll have 0.5L less displacement. About 415cc on the injectors, so 440's would work. Best to err on the rich side :)
Edit:
Yeah, the ECU plugs are different. I assumed he was thinking of using the 2JZ harness.
