Produced in 1986-1992 in the Ga70 mk3 Supra
Turbos used were CT12's
came with several different options & hp ratings
1986-1988
optional water to air intercooler or air to air front mounted intercooler
all ga70's were narrowbody in these years
all ran 6psi
all were yellow plug ecu's
yellow top injectors 295cc
185hp @ 6200rpm & 177ft lbs @ 3200rpm
1989
water to air intercooler eliminated i believe
ga70's still narrowbody
grey plug ecu introduced
9psi model introduced
injectors changed colour but cc remained the same (according to our flowtester)
i believe the larger turbos were introduced also
210hp @ 6200rpm & 203ft lbs @ 3800rpm
1990-1992
11psi model introduced in 1990 i believe
Ga70's now introduced as widebody
ga70's never had the whole electric seat luxury as do the ma70, only lumbar and side supports were electric
introduced with grey plug ecu was optional tems... (harnesses had tems connectors but not necessarily the tems struts)
I live in JDM New Zealand... and have not yet seen a ga70 with abs, tho it may exist
that's bout all i can think of
anyone got more to add?
1986-1988
all ran 6psi
1989
1990-1992
