1g ply. laser wheels
soundwave2000
Tenshou Getsuga
Sep 30, 2007
72
Somerville Tn.
I know the bolt pattern is the same, and Ill know Ill need spacers, but I have a set laser wheels that need tires and some work (I put steelies on my 'clipse)
they are the honeycomb wheels, Im tryin to see if anyone has pics of similiar wheels on a mkIII supra?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
Laser wheels? the ones that look like MKII wheels only 5-spoke? That would be awesome.
I'm pretty sure the bolt pattern is the same, but I'm not sure about the offset. I also think they're only 15" max, so they won't clear the front brakes.
clutchgordon86
n00b-Jersey
Feb 7, 2007
31
New Jersey
I actually had a set on my old MK3 when I junked it. They barely clear the brakes, so yeah, I would get some spacers if you wanted to keep them on there.
soundwave2000
Tenshou Getsuga
Sep 30, 2007
72
Somerville Tn.
The reason I want to use these wheels are because 1. I like the look of them 2. I have a set for my Eclipse but it doesnt run and is not going to for a while 3. Sawblades suck.
these are the wheels im tlaking about, but mine are going to be black with a polished lip
Sawbladz
1,727
Oshawa, ON, CA
clutchgordon86 said:
I forgot to mention that the center bore on the eclipse is much larger than the one on the supras. Not sure if that matters or not.
It matters but it is good that the center bore is larger. You can get a spacer to make is hub centric.
Sawbladz
1,727
Oshawa, ON, CA
The sawblades may be rather ugly, but they have one redeeming factor. When people make fun of your wheels you just tell them they are stock and that you are saving up for a proper set. Most people will appreciate this as they were probably in that position once. However, if you are the guy who intentionally installs ugly wheels...well...
soundwave2000
Tenshou Getsuga
Sep 30, 2007
72
Somerville Tn.
ms07s said:
:yelrotflm
Yea I hated them too. PITA to clean as well.
the best solution to this prob is for you to donate your advans to the "anti-sawblades of Tn" for testing and research. Anyway, You know which wheels I is speaking of, the 'clipse wheels.
ms07s
TORGUE!
Sep 29, 2007
1,083
Memphis,Tn
You will never get my advans so stop asking!:icon_evil Just strip the sawblades and polish them. Or paint them flat black and pretend they are steelies:sarcasm:
soundwave2000
Tenshou Getsuga
Sep 30, 2007
72
Somerville Tn.
Ok, I get the point that most of you dont like the looks. Not what Im asking, Im asking if anyone has pics of a Supra with a honeycomb style wheel like the laser wheels. I like the look of the wheels, and when I paint them I think they will look good, but again, thats my opinion.Anyway, I cant see why you think they are so bad, I see alot of aftermarket wheels that look similair. And if its fitment issues that yall dont like it no big deal, thats what adapters are made for, and a friend of mine is a machinest, so that means they are cheap for me.
